Modeling turbine housing
- Mute
- Permalink
- Report
I left the title vague because I suspect I will have ongoing questions on how to model this part properly.
The first question is based on properly modeling the scroll. My thought was to do a loft on rails however I can't figure out how to model the proper scroll curve.
The scroll is very simple based on the A/R.
http://www.turbobygarrett.com/turbobygarrett/turbine_housing_AR_and_housing_sizing
So the scroll starts at your determined AR where the inner curve of the scroll meets the base circle and the outer curve tapers from that measurement to zero where it meets the base circle.
I can kind of get something close to what I want using multiple conic curves but it's not perfect. I think I should be able to use a single conic curve to do this but can't figure out how. If a conic curve can't achieve this then how would you?
