Modeling Rubber Plugs
kris.chlapek
kris.chlapek
Hello All
Can I please ask for little advise as of how to project and model rubber plugs for the area marked on the picture? I just cannot work it out how to project the bore to anything sensible.
TheCADWhisperer
@kris.chlapek
How deep do you want to go into the hole?
BTW - your entire design process could be significantly simplified.
See Attached...
Now on to the caps.  Check back.
Now that it is completed - it is obvious that Sketch3 should have been created at the beginning not in Sketch1.
Edit: Now that I think about it some more - Sketch3 was not needed. (And if we get really fancy, Sketch2 was not needed either.)
kris.chlapek
Ideally full depth just to make sure it's not going to fall out
TheCADWhisperer
@kris.chlapek
Do you understand how to edit the model I presented to get the depth that you need?
kris.chlapek
Hello.
So I`m still a bit confused what is happening when you do the surface offset and then intersect. I tried to recreate it with little luck.
What i did instead was offset the bore in, and than patch the window and thicken.
TheCADWhisperer
@kris.chlapek wrote:
What i did instead was offset the bore in and then patch the window and thicken.
No file Attached to show what you did.
Did you figure out solution?
kris.chlapek
I`m sorry i tried to replicate this the way you did it with the plugs but i`m not acheving the angles. I don`t especially inderstand how the extrude intersects with the plug.
