Modeling Joystick Warthog for 3d print
jeanchris
Message 1 of 8
jeanchris
Hello every one.
First, sorry for my bad english....
I'm starting to use fusion 360 (I did some tutorial modeling knife, mk2 grenade...).
Now I would like modeling a warthog joystick (only the stick, not the base). But i don't know how to proceed and wich tool I must use (model, sculpt....)
Can you advise me on what to do? How to proceed?
I bought  turbosquid file but it's mesh file (*.obj, *.3ds) and i can't edit....
http://www.turbosquid.com/3d-models/3d-3ds-joystick-stick/1006788
Thank you in advance
Replies (7)
Message 2 of 8
kshea9RNL8
You can insert a .obj under the Insert icon.
Pic not clear at all for some reason but you can still see the location.
Message 3 of 8
jeanchris
Hello! thank oyu for your answer.
Yes I can import obj file in fusion 360, but I can't modify the mesh.... I want add some modification to the mesh...
Thank you
Message 4 of 8
kshea9RNL8
I see,
Well the good news is,  it can be done and someone that actually knows how 🙂 will I am sure answer your question shortly.
Message 5 of 8
jeanchris
Up!
Some advice please?
Thank you! Smiley Happy
Message 6 of 8
PhilProcarioJr
@jeanchris
How many polygons does the mesh have? I know a pretty straight forward way to do what you want but since I don't have the model I will have to figure  out what to use to show you.
Phil Procario Jr.
Owner, Laser & CNC Creations
Message 7 of 8
jeanchris
Hello PhilProcarioJr!
Thank you for your answer. The mesh have ~30000 polygones.
Message 8 of 8
PhilProcarioJr
@jeanchris
Ok when you import the mesh into fusion can you convert it into a B-rep on your system, and if so what is performance like when you do?
Phil Procario Jr.
