Model slice
Model slice
joergen_nilsson
Model slice
joergen_nilsson
How to slice a model using a non planar surface as cut tool?
Se supplemented model where I wish to slice the nose from the face into a separate body.
jhackney1972
You can use a Surface Body, that matches the shape of the head, to Split the Nose off into a separate body.  Model attached.
John Hackney, Retired
joergen_nilsson
Ok, thanks :-). I tried to sketch a half circle, rotated it to a surface sphere and did the same as you with no success!?
