MM
MM
MM
I have gone thru every preference and I can not get this SOB off MMs. I use inch and do not have the time to convert every thing to MM.
HughesTooling
In the browser expand the Document Setting folder, hover the mouse pointer at the end of the Units label and click and select inches on the dialog. Think there's an option to set your default there as well.
Mark Hughes
Owner, Hughes Tooling
Also there is a setting in the preferences beside user login name in pull down under drawings for units
