I seem to have a number of missing "Create" commands from my patch mode toolbar. Does anybody know how I can fix this? Currently I only have "Patch" and "Loft":
The video at the following link Create Surface Bodies with Sketch Features shows that I should have approximately 10 or so options as per the following screenshot:
I have a hobbyist edition of Fusion360 and am using Windows 8.1 Professional, if it matters.
Solved by joel.palioca. Go to Solution.
Sorry for the confusion that you are seeing. The video you are looking at is a video that was created prior to us changing a lot of our UI, but these commands are still accessable. To get yourself to a point where you can access these commands, what you can do is leverage our base feature command.
What this will do is put you in a direct modeling environment that will give you the commands you are looking for.
A couple notes around what is happening. Inside of Fusion we have two different ways to model, Direct modeing and Parametric. What you are doing when you create a base feature is we give you access to the direct modeling commands but all of the parameters that are normally part of a parametric model aren't with it. You can exit the base feature with the Finish Base feature command.
Cheers,
