Missing construct items: Axis/plane perpendicular/orthogonal to two axes/planes
不适用
1,122 次查看
6 条回复
1 条消息(共 7 条)
不适用
The two best ways to define a new plane or a new axis are:
  • New Axis orthogonal to two edges/lines/axis
  • New Plane orthogonal to two planes/surfaces
How come such basic and most obvious ways to construct new are missing or am I overlooking something?
Best
Hoegge
1,123 次查看
6 条回复
回复 (6)
2 条消息(共 7 条)
jhackney1972
You question is to ambiguous, please create a screen capture, anyway you can, of each condition you desire and post it.  The community cannot help unless they know the  orientation of the two lines to each other or the two planes.
John Hackney, Retired
0 个赞
3 条消息(共 7 条)
hoegge
Actually I don't think it is ambiguous or insufficiently described.
If two lines / axis / edges are perpendicular or even just in the same plan and not parallel - you can calculate the line / axis perpendicular to them both by calculating the cross-product:
https://en.wikipedia.org/wiki/Cross_product
Similarly with planes, if you take the cross product of the normal vectors to the two planes, you get a normal vector defining the plan perpendicular to both:
So it is a request to add the functions to Fusion to create a new axis orthogonal to two others and to create a plane orthogonal to the to others
Hoegge
4 条消息(共 7 条)
laughingcreek
I think it would be interesting to know why @Anonymous  thinks these are the "two best ways" to achieve this.  ok, I don't want to know in general, but rather in the context of parametric modeling.  Maybe I'll learn something new today.  An example would be great.
0 个赞
5 条消息(共 7 条)
hoegge
Writing for @Anonymous (my workplace alias). If you have two intersecting lines, it can often be useful to have the line perpendicular to them - i.e. to the plane they define. E.g. to create a new origin like construct.
The same with two crossing planes - to generate a new plane perpendicular to them - like the Z plane to the X and Y plane.
Also you can't even create an axis at a point on a plane - only on  face.
So all in all you are way to limited in creating new construction items from other items.
6 条消息(共 7 条)
lachlan.ahrensZNTNG
I've also encountered this issue, specifically needing an axis perpencidular to two intersecting axes, where no face is involved - only the sketch plane where the two axes (sketch lines) live.
My workaround is:
  1. Create a plane offset from the sketch plane (by any non-zero distance)
  2. Create a sketch on the offset plane, project the point of intersection of the two axes
  3. Create an axis through two points (the intersection of the axes, and the projected intersection point)
It's an annoying workaround, because the tool seems so close. "Axis perpendicular to face at point" should allow selection of a plane as well.
7 条消息(共 7 条)
HughesTooling
@lachlan.ahrensZNTNG  If I've understood, you could just enable 3d Sketch and draw a vertical line at the intersection of the 2 lines in the sketch. You should be able to use the line for anything you can do with an axis.
If you find you really need an axis the line can be used.
Mark Hughes
Owner, Hughes Tooling
0 个赞
