Missing body's
Missing body's
Missing body's
I opend a file today and two body's are missing. You can see in the image thumbnail (gears) shows two walls on either end of this design, but opening the file the two walls are missing. Where did they go? I've close the file and opened again and they are still gone.
jeff_strater
It's hard to say without looking at your model myself.  I do notice from your screen shot that there is at least one warning in your timeline (the yellow extrude feature).  If there are other failures in your model, it could explain things.  What happens when you do a "Compute All" command?
If you share a public link to your design, most likely many people will take a look at it, and someone will be able to help you.
Jeff Strater (Fusion development)
Jeff Strater
Engineering Director
This thing is being absolutely ridiculous! I made over an hour worth of edits, saved the file and closed. Just opened it and all edits are gone but they show again only in the thumbnail!
