I had found a you-tube video explaining how to make a knurl using the "Coil" and "Mirror" functions. I follow the tutorial and everything works, I can even see a preview (shadow) of the mirrored coil until I hit "OK". Then I get an Error message:
MIRROR 1
COMPUTE FAILED
THE SELECTED FACES DO NOT FORM A PATTERNABLE OBJECT. TRY ADDING OR REMOVING FROM THE SELECTION.
I have watched this video and keep trying over and over, only to get the same results. Is it possible there is something in my settings that I'm not aware of.
