Mirrored components names (and sum)
Hi everyone,
When I made new component with Create--> Mirror --> Components, new components are created with suffix (Mirror); otherwise when I copy / Paste components, new components are named with same name + number. This difference it becames evident when I put a Table inside a drawing: copy/paste components are summed in a row and mirrored components are summed in other row. Is there a workflow to obtain one row with all components summed?
Thank you.
Andrea
lichtzeichenanlage
If the legs are without any decoration you could use a rectangular pattern. If the legs are with decorations, but the table is square, you can use a circular pattern. This might work on rectangular tables, too. Depends on the dimensions. And finally you just could copy your components and join them by hand.
I don't understand your reply, is it a joke ?
Andrea
etfrench
The mirrored components are not identical to the original, so they must be summed as a unique component.
I suspect @lichtzeichenanlage meant to reply to a different thread.
ETFrench
Thank you for your reply, maybe you know a method to alterate the self generated tables inside drawings?
Andrea
