I have an XREF component "1" (made of components and other XREF components, weights 7kg) that is used in the main assembly. I did a mirror of this component "1", so in the browser, there is this XREF component with the XREF symbol and below it the local (Mirror).
When I select BOTH of them in the browser and RMB click properties, F360 shows only the 7kg, not 14kg. Very counter-intuitive and a possible source of big problems for the person using F360.
The whole mass-properties-material-assigning module in F360 is somewhat slow (no keyboard shortcuts for properties and material dialog, 1000x different steels in the same folder, ) and OH GOD there is no "override mass". We can conclude that weight is an important part of the engineering world.
You should also consider implementing a symmetry tool that would "mirror" the components and retain the names for BOM quantity and joints/symmetry around some plane.
