There's a post on the Idea station about mirrored offsets not being parametric here.
I made a test file and found an odd bug, I mirrored an offset circle and square when I change the offset for the circle the copy dosn't update but when I edit the square the circle and square both update. I've done a screencast to demonstrate, the file's attached, you need to edit the circle offset first then the square to see the bug.
Mark
Mark Hughes
Owner, Hughes Tooling
Mark
Mark Hughes
Solved by jiang_peng. Go to Solution.
Thanks for reporting the issue! I can reproduce the problem and logged as FUS-24725. We will start looking into it soon thanks
