I model many parts that are basically split rings. I begin by modeling the entire part as a solid ring. I then use the split body to create the upper and lower half of the ring, There are alignment dowels in the split line faces for alignment. I model the holes in the lower half and have tried to mirror the holes into the upper half body, However I can't seem to get it to work. Is it not possile to mirror holes into a separate body?
