Mirror feature not aligned
Message 1 of 9
Hello, I'm kinda new to Fusion and designing currently a case for my raspberry pi and created a snap joint on one side.
To add it on the other side, I choose the mirror tool, set it to feature and selected the first extrude to create the cutout.
However, it is not properly aligned. And I do not know why.
I tried to select the component and align it to the Z axis. But it did not solve the issue.
Replies (8)
Message 2 of 9
jhackney1972
Please attach your Fusion 360 model so the Forum users can assist you with your file.  To attach your file, open it in Fusion 360, select the File menu, then Export and save it to your hard drive. Then attach in to a forum post using the Attachments section.
John Hackney, Retired
Message 3 of 9
Sure. Here is it.
Message 4 of 9
jhackney1972
I do not find any case in the Fusion 360 file that your attached.  It is only contains the PC board and components.
Message 5 of 9
jhackney1972
Sorry, I just found it.
Message 6 of 9
jhackney1972
Activate the Case component, go to the first sketch and constrain it to the origin to center the sketch.  This will align the mirror plane and give you the alignment you need.
Message 7 of 9
HughesTooling
One problem is the warning in the timeline for the capture position.
Next problem is your part is not symmetrical around the document origin. Above I created a mid plane using the outside faces of the part and you can see it's 0.213mm off centre.
One bit of advice, you should not have any capture position s in your design, if you need to position a component use a joint. And for this design there should be no problem creating the bodies in the correct place from accurate sketchs.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 8 of 9
Thank you! That helped me a lot.
Message 9 of 9
Mark
Oh, don't know how this happend. But like I said first time user. So most of the time I have no idea what I am doing 😄 But thanks for the help. Hopefully got everything fixed now.
