Mirror feature across 2 planes.
sdavila6
sdavila6
Ok this might be an easy solve, but I can't seem to figure it out. I need this same swept cut on the other side of the ellipse, but sweeping the opposite way. Essentially I need to mirror it across the 2 planes (horizontally and linearly). Any Advice?
sdavila6
Figured it out. Used the Circular Pattern function, lowered the instances down to two, and revolved around the y-axis.
Thank you so much!  I have been searching for this solution for about 4 hours, and was going to open another thread.  I will use this often.
