Mirror Command in Modeling Environment
I need some assistance in creating designs on the surface of the box. I tried to create a box in the modeling environment and split the body into 4 equal parts with an intention to use mirror tools, so that the sketches on one part would reflect on the other three parts of the box. But the mirror tools are inactive. Is there any command equivalent to the internal mirror in sculpting environment?
Thank you
TrippyLighting
Share the models, make a screencast or post screenshots or all of the above. If you want to be helped please provide a bit more information.
schneik-adsk
You will find the mirror feature in the create panel with patters. The create feature can mirror faces, bodies or features. These are not live like sculpt but they are associative. That means if you edit the geometry you mirrored in the timeline then the mirror will update. If you add features after the mirror in the timeline, the mirror does not update.
Kevin Schneider
