Mirror Command in Modeling Environment
適用対象外
550件の閲覧回数
2件の返信
メッセージ1/3
適用対象外
I need some assistance in creating designs on the surface of the box. I tried to create a box in the modeling environment and split the body into 4 equal parts with an intention to use mirror tools, so that the sketches on one part would reflect on the other three parts of the box. But the mirror tools are inactive. Is there any command equivalent to the internal mirror in sculpting environment?
Thank you
0 件のいいね
551件の閲覧回数
2件の返信
返信 (2)
メッセージ2/3
TrippyLighting
Share the models, make a screencast or post screenshots or all of the above. If you want to be helped please provide a bit more information.
メッセージ3/3
schneik-adsk
You will find the mirror feature in the create panel with patters. The create feature can mirror faces, bodies or features. These are not live like sculpt but they are associative. That means if you edit the geometry you mirrored in the timeline then the mirror will update. If you add features after the mirror in the timeline, the mirror does not update.
Kevin Schneider
0 件のいいね
