09:14 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I actually have several questions:
1. is there a rule of thumb that you should always start with an inside or outside dimension first.
2. Is it best to build this as a cylinder (because I want to make the 3 hole pattern in the middle and need an axis) or as a circle.
3. when I am press pulling an object how do I achieve this on both sides at one time. (I tried the midplane on the center circle) it didn't work because the program included the in hole cylinder dimension which resulted in one side being longer than the other.
Thanks.
