Mirror body method
Mirror body method
smallfavor
Message 1 of 12
Mirror body method
smallfavor
I've in the past been able to mirror a body or element by selecting a snap point on another body to serve as the axis of the mirror plane.  The tool used the active construction plane to determine the direction of the mirror.  This doesn't seem possible in this app as there's not apparent snapping options in the modeling mode.  Is there some way to quickly mirror bodies without having to draw a line or new construction plane?
Replies (11)
Message 2 of 12
TMC.Engineering
I don't think so.  there is no active plane construction plane unless you are sketching.
you can turn on the origin and use any of it's planes.  or a face of a body without adding extra planes
mirror can be used on faces, bodies, features, and components.  so make sure you have the appropriate type selected
I also recommend watching some of these videos if you haven't seen them yet.  the first one does a good job of explaining how fusion is different..
Timm
Engineer, Maker
System: Aorus X3 Plus V3, Windows 10
Plymouth Michigan, USA
Owner TMC Engineering
Message 3 of 12
smallfavor
That's a bit frustrating.  Perhaps I should make a request.  As it is now - to the limits of my skill at this point - I can'd stand to have to make such effort.  I can't even manage to select bodies to move as you can see in the vid.  I have to go up to the selection filter and change it to bodies before I can manage to get things done.
Message 4 of 12
TMC.Engineering
What kind of structure are you trying to make?
If you attach your design I am sure the community can help.  To me it looks like you are trying to have 4 (possible identical) parts that are assembled.  Is that what you are doing?  I am also wondering if you want to pattern bodies instead of components.  without knowing your intent it is tough to say.
I would recommend that you don't try to force fusion to be another software, it never will be and you will just get frustrated.  theses videos do a good job covering fusions intent.
Timm
Engineer, Maker
Message 5 of 12
smallfavor
I've watched a good deal of vids but I always come up against something not covered.  What I'd like to do is place copies of a couple of supports on the other side of a base structure.
File attached
Message 6 of 12
TMC.Engineering
Heading out to dinner but I will look at it later.  I would mirror components and then use a rigid joint with offset to position
Timm
Engineer, Maker
Message 7 of 12
TrippyLighting
Let's go through this one by one.
1. You should have fixed these warnings (yellow icons) and errors (red icons) in the timeline when they ocurred. Ignoring these is going to make life much more difficult down the (time)line.
2. Your sketches are almost fully undefined. You should use dimensions. For the slats you may want to consider using a pattern.
3. You are using a skeleton sketch to make the cut-outs for the slats, but instead of using that same sketch to make the slats you create one slat body, then pattern is and because the pattern does not match, you move each body individually. This is very inefficient.
In general Looking at your design, you are using a sort of skeleton design, where you create several bodies from one sketch. Perfectly fine.
However , all of those bodies should be turned into components and perhaps assembled with a rigid group. Review Fusion 360's R.U.L.E #1
Then of you do need to move stuff, move components, not bodies.
I might work on a screencast to see how this can be done more efficiently.
Message 8 of 12
TrippyLighting
Your sketching technique is questionable. Drawing rectangles with overlapping lines will cause trouble when trying to fully define/constrain a sketch.
I am also wondering how you managed to draw sketch geometry without constraints. e.g no horizontal/vertical constraints.
Message 9 of 12
smallfavor
I don't yet fully comprehend how to use the time line effectively.   In my older cad app I was able to revert to a stage, select something and bring it back up to present.  I'm getting off to a poor start on this aspect.
I had several more constraints at first to create the sketch but then deleted what no longer seem necessary.
Yeah, I had to move all those bodies manually because I couldn't get them to line up using the pattern tool.  I was using the rectangle pattern and no matter what, the copies would not coincide with the slots of the side supports.  So giving up, I manually had to move them each a bit into place.
There's a good deal of unlearning necessary for me to use this new app.  I suppose the constraints in organizing are the key to Fusion's modern functionality.
I would find reading discussions about the philosophy of the interface very appealing as I think having a better understanding of such would make learning it more efficient.  For instance I just caught it that bodies are really sort of parts in waiting and are just as easily considered tools until they become part of a component.  I'm also likely a bit slower than most when it comes to understanding software
Thanks for the help!
Message 10 of 12
TrippyLighting
I've cleaned the sketches from all double, fully overlapping lines and aded all necessary dimensions.
See if what you can learn from going through the timeline. There are many ways to design something like this. I simply used the sketches to their full potential. So if you change the dimensions in the sketches, that's what drives the rest of the design so far. It's not fully debugged. I'll leave that to you 😉
Message 11 of 12
smallfavor
Thanks very much for your help!
I see how you avoided overlapping lines by creating a U shape with constraints.  Did you use the pattern tool to distribute them?
Next there's an extrusion for the sides but I see no move record.  When you create extrusions from the drawing when how did you place them?
Next it seems you extruded all the slates from the drawing and converted them components - yes?  I'd originally done the same but I thought creating a component first and making copies would give me an easier time making changes to the width.
Next it seems you created a component then copied and pasted all the base parts into it, made a group and then - what's 'rigid group;?
Then the mirroring plane - did you place that by offsetting it or was that done with the plane along path or what ....?
Message 12 of 12
TrippyLighting
Yes,
When creating the extrusion it does not have to start at the sketch plane. It can start and stop at an object, the two blue highlighted sketch points in the screenshot.
That depends 😉 That's the reason I dimensioned only one slat and then use the pattern tool to repeat that profile.
Now when you change the sketch dimensions, the slat dimensions and associated cuts in the rail (or what ever that's called) change as well.
However, the disadvantage is that when you make a BOM, all the slats are called out as individual components, not as one component with a quantity.
You can still only extrude one slat, convert it into a component and then create a component pattern with the same distance as the pattern in the sketches they always align.
The bottom horizontal line in the Base_Rear sketch has a vertical construction line drawn at the middle point. I created a "plane at angle" at 90 degrees. Whatever the width of that rear profile is, that plane will always be at the middle of it, s that's what I am mirroring about.
In general in a parametric design I try to avoid moving bodies.
