- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have a 1x4 with a pattern of 3/4 inch diameter pins.
The bins are flush with one side of the 1x4 and protrude out the other side by two inches.
I would like to mirror the 1x4 and its pins.
My workflow is as follows.
Position all elements as bodies.
Select the 1x4 as a body along with the 13 pins.
Select the side of the 1x4 with the flush pins as the mirror plane.
Press ok everything mirrors as expected.
I would like to move the mirrored copy to a 1 1/2 inch space from the mirror original element.
I converted everything to components and then move the 1x4 and pins as a group.
Everything moves as you would expect if you move it toward the original copy of the mirror. However if you move it beyond its original position at the end of the mirror command the pins and the 1x4 shorten as it approaches the original posiion.
Allan Steinkuhl
