Mirror a mesh object
I have got several scanned meshes, that I have to mirror.
The tutorials and forum entries show a menue point, that I am missing: "Mesh to BRep".
As far as I learned, converting to BRep only works for meshes with less than 10.000 faces.
So I reduced the mesh to 9.999 faces, but still no possibility to convert or to mirror.
Richard.
Menue missing Mesh to BRepMenue missing Mesh to BRep
TrippyLighting
What would you want to do with the end result ?
Working with triangulated meshes in a CAD application is not the best idea.
I need the scanned objects in order to model a monocoque around it.
So, I just have the dampers on one side, but need them mirrored to the other side. There I have to model the correct suspensions on the monocoque.
I don't want to work with the mesh, but rather use it as reference.
TrippyLighting
In that case I'd mirror the needed mesh objects in Autodesk Meshmixer ( maybe that can also be done in the Mesh environment n Fusion 360. Not sure) and then re-import the mesh int Fusion 360.
Converting a mesh into a BRep makes for a very heavy model and having more than one model like that in a design can cause performance problems. That is the reason for the 10k/20k conversion limit.
Just use the mesh as a visual reference.
Thanks for the advice.
I will not going to mirror the scanned meshes, but rather use them as reference: build the constraints from the mesh as a clean model, delete the mesh and then mirror the clean model. I think this is a better procedure by just using the scanned mesh as reference only.
And you are right by keeping the filesize small!
Richard.
