Migrating from PTC Creo to Fusion 360 - Workflow
Hello 360 Community!
I happily stumbled across fusion 360 in my pursuit for some cad software for my startup. I am a long time CREO user, back to wildfire 3.0 (pro/E) now on Creo 3.0 at work.
I am having serious difficulty adapting to the workflow of Fusion 360 from Creo. Does anyone have any suggestions as to how to beat this learning curve. The tutorials and 101 training are helping, but any tips or pointers would be great. I am talking more in the modeling realm here than the CAM or RENDER.
Thanks!!!
martin.zatecka
Here are some additional learning materials and resources:
Youtube channel
• Autodesk Screencast website
tips and tricks:
http://forums.autodesk.com/t5/post-your-tips-and-tutorials/bd-p/453
Please send us any question, we are looking forward to help you.
regards
Martin
Martin Zatecka
UX Designer
fredsi
Mpatane,
You are having the same exprience many users have when coming from traditional parametric modelers (Creo, Solidworks, Solidedge, Inventor, etc.). There are a number of resources available as mentioned in the first response to your post. It may also be instructive to read through the discussion in this thread:
http://forums.autodesk.com/t5/general-fusion-360-questions/getting-the-workflow-right/td-p/5571611
The Fusion team has resisted publishing a 'right way to do things' for two reasons (IMHO). First, there are a number of work flows that can be used to achieve the desired result, but it depends on what that result is; for example is it a quick conceptual design or a detailed mechanical construct. The second reason is that the software continues to develop rapidly. Sometime in May the next major release is due; it is scheduled to contain the functional equivalent of external references - the type of part reusability found in the parametric modelers mentioned above. This should provide you with a familiar and comfortable workflow so you can be productive immediately.
Fred
prabakarm
Mpatane, Fred,
Based on the feedback we are working on learning content around transitioning from other CAD.  We are targeting this for May as well.  In parallel we are also discussing how we could do best workflow practises content without dictating a presecribed path as we believe exploration drives creativity.  We might not have the right answers.  We want tool be flexible for you to explore and on our end strive to deliver on that flexibility along with learnability.
Prabakar.
I would suggest that you forget everything you learned about CAD when starting out in Fusion. I would suggest you make your sketches as simple as possible. Aiming to fully define a sketch in Fusion is a futile task. Aim to do as much with 3d geometry as possible with things like Combine, fillet, chamfer etc. Realize that "documents" are not really assemblies as much as they are a ton of parts that can be positioned with joints. That means their position is captured with timeline features. Every few steps try to break your model so it stays robust throughout the entire process!
There are two camps with components; never work in them and let Fusion handle it, or always work in them explicitly and force Fusion to handle it. The first one is easy but sometimes you'll find yourself stuck trying to do something simple like move a component. The second one requires focus and will take away from the experience.
Eventually you'll figure out that you can crank out robust sub-assemblies really quickly without much hassle. Good luck!
Note: Learning Fusion has forced me to think a lot about how CAD systems work and as a result I have become a far more powerful user in other CAD packages. Kind of a nice perk of learning Fusion.
Can't forget everything when I need my CREO skills for my job. Hope you can find a way to teach without a requirement for a mind dump.
