Midpoint Constraints
KLathwell
KLathwell
Hi Guys
I am struggling trying to constrain to mid point, hopefully the screen cast will explain my dilema
ScreenCast URL: https://autode.sk/2Ni9oSk
Google URL: https://knowledge.autodesk.com/community/screencast/1b4d825a-c3bf-4e2b-ba11-b7d981075976
TheCADWhisperer
Can't you do this with a Coincident or Colinear constraint?
johnptc314159
i might go back and draw a point where you want and constarin to it 🙂
davebYYPCU
Your rectangle vertical articles are black, therefore fully constrained where it is now.
so for them to move will need one or more dimensions removed / edited.
Measure the gap, dimension the centre line to “gap / 2.”,
or use symmetry Constraint,
so many ways.
Might help....
laughingcreek
shift will expose the midpoint of a construction line.-
shahriarsifat1802164
I think you are trying to do like this.
(Note: All the dimensions are arbitrary here)
Md. Shahriar Mohtasim
Dept. of Mechanical Engineering,
RUET
LinkedIn | Facebook | Youtube (CADs) | Twitter
Autodesk Product Users, BD
If you found this post helpful please hit the LIKE button and for a solution hit the ACCEPT SOLUTION.
Thank you.
Here is the screencast link:
Find the midpoint | Fusion 360 | Autodesk Knowledge Network
Thank you.
RUET
Thank you.
