Patterns
Patterns
Message 1 of 17
Patterns
Im been testing fusion 360 for about a week so im really new to this 3D drawing world, im stuck at this problem.
Im trying to make a pattern to my model looking like this(picture) but I cant seem to figure out how.
Replies (16)
Message 2 of 17
etfrench
The first step is to attach your file to the thread 😀  (File/Export/Archive file *.f3d)
ETFrench
Message 3 of 17
shahriarsifat1802164
You need to select a pattern along path.
go to create >> pattern >> pattern along path
Md. Shahriar Mohtasim
Dept. of Mechanical Engineering,
RUET
LinkedIn | Facebook | Youtube (CADs) | Twitter
Autodesk Product Users, BD
If you found this post helpful please hit the LIKE button and for a solution hit the ACCEPT SOLUTION.
Thank you.
Message 4 of 17
Thank you.
RUET
Thank you.
Message 5 of 17
TrippyLighting
And that resembles the pattern in the image ?
Message 6 of 17
Not the holes, the grip on the handle
Message 7 of 17
Could not edit my post so I post it here
Message 8 of 17
You need to thicken your model
Then cut the same shape you have provided on that image and then pattern that feature either linear pattern or pattern along path.
Thank you.
RUET
Thank you.
Message 9 of 17
TrippyLighting
My first concern is that you have the timeline turned off. For beginners, this is not recommended.
My second concern is that your sketches are not fully defined (constrained and dimensioned).
@shahriarsifat1802164 can you demonstrate what you are suggesting? I think as so often you have misunderstood the question. Completely!
Message 10 of 17
TheCADWhisperer
Robust Modeling StrategiesRobust Modeling Strategies
Message 11 of 17
the Circels in the sketch has no funktion, they are just there so I know where to make the counterbore holes later on
Message 12 of 17
g-andresen
here is one possible way.
günther
Message 13 of 17
your on to something there
Message 14 of 17
TheCADWhisperer
Then the most certainly do have a function.
This does not change anything that I wrote.
Message 15 of 17
g-andresen
Version 2
günther
Message 16 of 17
laughingcreek
what the heck, here's my go at it-
Message 17 of 17
wow thats awesome! Your a genius! opend the file and was so eazy, thanks alot 🙂
