Midplane Bug
Midplane Bug
merik
Midplane Bug
merik
Hi Everyone
Had a strange one today. I was creating a midplane on an object and it works in two axis but not in one.
To explain in more detail with some screen shots:
Create midplane, select two faces, all good.
Now select the left and right faces:
The midplane shows up on the left not in the middle. However if I edit the feature:
You can see that it is in the middle.
I have attached the file that causes the problem.
Thanks.
jeff_strater
yes, that is a bug all right.  I will file it.  Thank you for sharing the design file.
Jeff
Jeff Strater
Engineering Director
davebYYPCU
Not fixed yet?, or is this with different inputs,
Both planes selected are Plane on an Angle at 90 deg
Can work around it....
