Mesh (.obj, .stl) rendering issue
bruna.glokovic
Message 1 of 16
bruna.glokovic
I have made a solid body (ceramic bottle) in Fusion and then exported it as .obj to Blender. After embossing an ornament on the bottle in Blender I have exported an .stl and .obj file back to Fusion. Next step was adding and adjusting material to the bottle after which I rendered the bottle (I have tried doing that on both .stl and .obj files). In-canvas rendering seemed just fine, however the cloud (and local) renders distorted the material. Does anyone have an idea why this happened? I have attached both renders below. It is important for me to have a cloud/local rendered image since I can't really use the in-canvas render due to the limited resolution.
P.S. I have tried adjusting the texture map controls and scaling the material, all results were the same
Replies (15)
Message 2 of 16
TrippyLighting
Can you share one of the .obj files created by Blender ?
.obj and .stl files do NOT contain the same information. When you export geometry from Fusion 360 into a .obj file it will include custom vertex normals, or in Blender's terminology custom split vertex normals.
A .stl file does not contain those and for rendering that can make a difference.
See my last post in this thread
Message 3 of 16
bruna.glokovic
Thank you for your answer! Unfortunately an error keeps coming up when I try to attach the .obj file, I'm not sure why
I'm aware of the information .obj and .stl contain, but confused over how the material is accurately portrayed in the in-canvas mode and lost in the cloud render mode. The same .obj file and material were used in both render modes
Message 4 of 16
TrippyLighting
Zip it and then attach it 😉
I cannot answer the cloud vs. canvas question.
Is there a reason you don't design and render these objects completely in Blender?
Also, I'd be happy to show you how to "emboss" these symbols in Fusion 360 (not the emboss tool).
Message 5 of 16
bruna.glokovic
Here it is, thanks again!
The reason I render in Fusion is convenience, I have never rendered in Blender, but am planning to work on that some more anyway. I would very much appreciate it if you could show me how to emboss the .svg drawing/ornament in Fusion, yes! 🙂
Message 6 of 16
TrippyLighting
You need to zip the .obj file, not the .mtl file 😉
Message 7 of 16
bruna.glokovic
Sorry, third time's the charm I guess 🙂
Message 8 of 16
TrippyLighting
Interesting. How did you do this in Blender ? Shrink-wrap the pattern around the object and then a boolean subtract ?
Can you share the original Fusion 360 model ?
Message 9 of 16
bruna.glokovic
Yes, that's exactly how I did it. I had some issues with the .svg file (the pattern), but after cleaning up the vertices I managed to get the right shape embossed on the bottle
Message 10 of 16
TrippyLighting
If you designed the original in Fusion 360, I need the original Fusion 360 file.
Please export as .f3d and attach to the next post.
Also, if you have a .svg for the pattern, zip and attach that as well.
Message 11 of 16
bruna.glokovic
Here it is:
Message 12 of 16
TrippyLighting
Hi Bruna,
I ran into some troubles importing the .svg in Fusion 360
It opens fine in a web browser (Google chrome).
I can probably workaround this with a mixed Blender/Fusion 360 workflow.
Message 13 of 16
TrippyLighting
All my attempts to use the .svg in some form failed.
I had to re-create the p[attern from scratch with the native tools in Fusion 360.
So slowly but surely I am making some progress.
Message 14 of 16
bruna.glokovic
This happens to me sometimes with .svg files in Fusion. Usually reuploading does it, but some always upload “broken”. Thank you for your efforts! I can try exporting it again if you haven’t managed to fix it
Message 15 of 16
TrippyLighting
Here is a screen recording of how I would approach this in Fusion 360. It's not a perfect solution, bit might be good enough:
Message 16 of 16
bruna.glokovic
Thanks so much! 🙂
