Mesh convert
Mesh convert
APOSTOLISZEV
Message 1 of 18
Mesh convert
APOSTOLISZEV
I am having some issues  and i can't do it right when i am trying to convert this mesh file into a solid body.
Can someone help me with that please.
Thanks a lot,
Apostolis Zevgaras
Replies (17)
Message 2 of 18
jhackney1972
Mesh needed to be repaired first.  Your model is attached.
John Hackney, Retired
Message 3 of 18
APOSTOLISZEV
I want to make changes on the model(like extrude etc.).
I tried to do it with the prismatic option but it did not worked propertly...
In the file attached i show you that my model is not proper converted.
So i want to have a solid body.
Thanks a lot
Message 4 of 18
jhackney1972
In your original post you simply asked for someone to help you convert your STL mesh to a solid body which I did and sent it to you.  Then you "modify" your request to get a "prismatic" solid body.  I have reconstructed the model using Mesh Sections, it is attached.
Please do not forget to select the Accept Solution icon or ask further questions.
Message 5 of 18
TrippyLighting
This geometry is too complex in curvature for the prismatic conversion to to work. You'll have to remodel this from scratch!
Message 6 of 18
BrandonMac
Convert mesh now a plug in?
Message 7 of 18
TrippyLighting
Nope!
Message 8 of 18
BrandonMac
Message 9 of 18
TrippyLighting
The mesh in your screenshot looks like a quad mesh modeled in a Sub-D modeler. You would not use the mesh workspace to convert that into a triangular mesh as that would be complete nonsense.
You would convert this into a T-Spline.
Message 10 of 18
BrandonMac
 who said anything about Triangles. I do this conversion your years now into SW. Just the menu seems odd to me. thanks anyway.
Message 11 of 18
TrippyLighting
I think you did not understand a word of what I wrote!
Could you create a screencast of how you do this in SW so we can suggest how this might work in Fusion 360 ?
Message 12 of 18
TrippyLighting
If you want help, a concise and cohesive description of what you are trying to achieve goes a long way.
The mesh convert you are referring to in your screenshot in the default setting (prismatic) will automatically triangulate your nice quad mesh and then convert each of these triangulate facets BRep consisting of 1-degree NURBS surfaces.
That creates a very "heavy" solid model and I have a feeling that isn't what you want.
Message 13 of 18
BrandonMac
The image you posted directed my to a paid  Plug-in source.  i reporting it as a bug now with a case number.
Message 14 of 18
BrandonMac
Not sure why could be random the old menu seems to be working now. Convertmess.jpg
Message 15 of 18
TrippyLighting
@TrippyLighting - this post has been edited due to Community Rules & Etiquette violation.
And that, my friend, is a T-Spline!
Message 16 of 18
BrandonMac
Message 17 of 18
TrippyLighting
The "convert mesh" is in the mesh workspace and the "Convert" menu to convert a quad mesh requires a user to first create a new form and then convert the quad mesh there into a T-Spline. However, whether a mesh is triangulated, or not, it's still a mesh.
When a user inserts a mesh it is only natural that they'd be looing in the mesh workspace to convert the mesh.
Could the conversion to a T-Spline be added to the mesh workspace for easier discoverability ?
Message 18 of 18
lauri_barnhart
All replies have been turned off by the moderation team due to derailing of the conversation and an accepted solution has already been given. We encourage you to create a new thread on a similar subject as you feel necessary.
