You need to use the scale command. I have just shut fusion down for the night or I would give you a screen shot.
I think it is in the Modify menu and allows you to re-scale in each or all three dimensions. Callibrate may also work
but I don't work with meshes often so I haven't tested it.
The normal reason this happens is because when you import these files into fusion, fusion can only see a scale in
"units" and so fusion uses its own default unit which is likely different. The other software might use some subscale
unit to model and so 100 might only be 10mm but fusion calls 100 that many millimetres.
Cheers
Andrew
