merge coplanar triangle faces
I am working with a pentagonal hexecontahedron. Each "face" is a irregular convex pentagon. The mesh I was working from, each pentagon was made up of eight triangles. Using various tools, I was able to export that mesh as a solid.
I want to be able to push and pull individual pentagon faces without other pentagons breaking up into non coplanar triangles. I was able to do this in 123d design but with a dodecahedron. Now I am moving up in number of faces.
Can I merge triangles into pentagonal faces? If so, how?
TrippyLighting
Can you at least attach an image or perhaps better share your design and maybe make a screencast ?
I found the right tutorial!!
Yoyosten
Community Visitor
Community Visitor
I do not see the "Mesh to BREP" on mine.
g-andresen
6 years later something has changed
günther
jhackney1972
In the Mesh Environment, under Modify menu, I think this is what you are looking for.
John Hackney, Retired
