How to prevent zooming when rotating an object to create an animation
bradanlane
bradanlane
As part of most projects, I create a short animation "movie" to show the finished product. This starts with a slow, 360 degree rotation of the object. When I play back the rotation, Fusion has automatically added zoom in/out which I did not do when adding the key frames / stop points.
I've tried lots of things and none have eliminated the problem.
It turns out that using the mouse to change position of the object is somehow introducing this problem.
If I use the "Transform" dialog box, I can get a smooth 360 rotation about a single axis.
I have no idea why doing it via the mouse is the problem but at least there is a method that works.
(BTW: this originally started as a question but then I stumbled upon the above solution).
lucasliraAU
Hello Friend!
In this brief tutorial released are some instructions to work with a product animation, so to be able to understand about your problem it seems that you are having some problem regarding the transition of camara during your animation for this tutorial is going to help note that the point important in the (VIEW) should be triggered and deactivated during the elaboration of the animation.
I hope I have helped you!
Good luck in your projects.
Lucas Lira - Fusion 360 Technologies, Design and Applications - Autodesk Hub Diamond
Direct contact at: https://www.linkedin.com/in/lucaslirasantos/
VEX Robotics Engineering in Brazil - https://www.vexforum.com/u/lucas_lira/summary
Main Researcher and Technology Applications in Nerd Factory - https://www.fabricadenerdes.com/
Hey Fusion,
For some reason, every single time I open one of my designs, it zooms out really far and it gets irritating to spend a couple minutes every single time I insert a part, change the view I want to see my design, or open the document to zoom in a lot. Is there a way I can fix this?
(My design in on another account)
