Menu colors setup could be better
WHolzwarth
Mentor Mentor
Message 1 of 9
WHolzwarth
See picture
Black on light blue is ok, But I don't like gray on darker blue.
Walter
Walter Holzwarth
Replies (8)
Message 2 of 9
ADSKDJW4
Walter, please consider posting this in the Fusion Ideas forum as an enhancement request. This way it can be voted on by other users too.
Fusion 360 Idea Station
Don
Message 3 of 9
WHolzwarth
Done a few minutes ago, Don.
Walter
Walter Holzwarth
Message 4 of 9
WHolzwarth
Hmm. Someone - not me - accepted a solution for this problem.
For me this problem still exists. It's obvious, and should be changed without  an additional entry in IdeaStation.
Walter
Walter Holzwarth
Message 5 of 9
ADSKDJW4
Hi Walter,
This was an internal acceptance as we just wanted for others to know this is an enhancement request at this time. The word use for "solution" is poor here as I understand its not solved. Thank you for your understanding here. I am hoping this will be added to the preferences.
Don
Message 6 of 9
WHolzwarth
I'm hoping that, too.
I can't imagine anyone being able to read this on a mobile device on sunshine.
Smiley Wink And this mobile worldwide access seems to me, what you want to make us desirable, Autodesk.
Walter
Walter Holzwarth
Message 7 of 9
bob_holland
Autodesk Support
Autodesk Support
Walter,
I just wanted to let you know that development is aware of the issue.
I do not know where it is on the roadmap.
Thank you again.
Bob Holland
Autodesk Product Support
Message 8 of 9
WHolzwarth
Well, for me, there's no need for any roadmap.
Just do it. It's no big deal.
Walter
Walter Holzwarth
Message 9 of 9
JamieGilchrist
Hi Walter,
yes this will be changed.  the UX team is combing through the application to fix UI problems like this and rationalize and simplify the abundance of colors used so, you the user, won't run into this sort of issue.  you can look for this issue, and others like that we come across, to be fixed over the next couple of updates.
Thanks for pointing this out and rest assured, we are on it!
hope this helps,
Jamie Gilchrist
Senior Principal Experience Designer
