Mechanical Design Certificate questions
Fleiscal01
Message 1 of 11
Fleiscal01
Hello!
I'm studying for my mechanical design certificate and I'm hoping someone will have an explanation for a few of the questions its marking wrong.
I was taught that a green line in the the form workspace indicates symmetry, and a lock icon on the sketch in the browser means that it is fully defined, however both the pre test and post test marked them wrong, but I can't find any information stating otherwise.
These 2 are completely stumping me. Any thoughts?
Thanks!
Abbey
Replies (10)
Message 2 of 11
TheCADWhisperer
@Fleiscal01 wrote:
I was taught that a green line in the the form workspace indicates symmetry,....
I haven't seen these tests - but I suspect there were some subtle qualifying words in the question that you missed.
Who made up this test?
Can you ask your instructor to join this discussion?
Message 3 of 11
Fleiscal01
I'm on break from school right now, so I'm in between professors.
But this is the prep course for the Autodesk CAD for Mechanical Design Associate certification.
Message 4 of 11
TheCADWhisperer
I think you are looking at the wrong questions for the red X.
What where the two questions preceding the X marks?
What was Figure D?
Message 5 of 11
Fleiscal01
I took the test again, those 2 questions are now marked correct but other questions that were marked correct previously are now marked incorrect. Is there a support specifically for the certifications and learning pathways?
Thanks!
Message 6 of 11
Fleiscal01
Message 7 of 11
TheCADWhisperer
The correct answer is B NOT D???
Message 8 of 11
TheCADWhisperer
...so what was the other preceding question?
I'll make significant wager that you got that one wrong too.
Message 9 of 11
Fleiscal01
You might be right, but can you explain? I thought B was a Plane, not a face which is why I didn't choose B.
I'm sorry about that, I'm thinking it might be time for a brain break. thank you!
Message 10 of 11
TheCADWhisperer
@Fleiscal01 wrote:
...time for a brain break.
Too late, I think it is already broken.  😉
Message 11 of 11
davebYYPCU
You can’t create a sketch on a curved surface.
