- Mute
- Permalink
- Report
I have a fair bit of experience in Fusion, but I've always had a problem to which I haven't found a solution on the forums. When I use the measure tool while in a sketch, the results are not visible because the window is tiny. I would like a full size window like when I measure outside of a sketch, because inside a sketch I have to go into the measure window and scroll. This interrupts workflow. Additionally, more often than not I will have to orbit my view to see what the black measuring vector has spelled out. In the example I attached, the arrow doesn't even have a readout! You can scroll the view any which way but it's just a useless plain black line.
Firstly, is there a way to make the measure window bigger? Secondly, why can I often not see my dimensions in the workspace?
