- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have noticed an unexpect behaviour of the measuring tool when measuring the distance between two circular features (holes or extrusions). If, with the measurement tool active, I select the borders of the two features, I get 2 measurements: the distance between the circle centers and the minimum distance between the circles. The problem is that the distance values are superimposed, making them impossible to read (see below).
Of course, this is not a critical problem, as I can always get the values from the Measure Window, but it is really annoying.
It would be much better if Fusion offset the position of one of the values.
