measuring angles
measuring angles
prefetch
measuring angles
prefetch
i want to notch some pipe to match this drawing i made, but i'm not sure how to measure the angle of the pipe.
usually when i want measure something i hit the 'i' key and measure distances and things.  what's the best way to do this for angles?
i was thinking about maybe drawing a sketch on top of this and when i place the lines i see what angle they come in at, but it seems like there must be a more precise/direct way to do this.
any ideas?
Beyondforce
Hi @prefetch,
In this situation, I'll sketch simple lines and use the pipe command to create those pipes. This way, it will be the easiest way to create the pipes and measure angles.
From your question, I understand that you have created circle sketches and the extruded them to create those pipes. Try the above technique and let me know, if it helps.
Cheers / Ben
Check out my video channel: Fusion 360: Newbies+
Ben Korez
Fusion 360 NewbiesPlus
Fusion 360 Hardware Benchmark
| YouTube
San_Escobar
Hey prefetch
Assuming the geometry end is trimmed, I would create a new sketch on related plane (same view of your picture) and then project this edges that you want measure... That is it.
Hope this helps.
If this solved your issue please mark this posting "Accept as Solution". Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Happy
HughesTooling
Another option is use axis through cylinder\cone\\torus then use the inspect tool and select the 2 axis lines.
Mark
Mark Hughes
Owner, Hughes Tooling
prefetch
thanks everyone for the suggestions.
mark, the axis-through-cylinder and then using inspect worked great.
thanks!!
