Measure tool - Angle?
Ezekiel12
Ezekiel12
so can the Measure tool measure an angle between two edges? Or do I set something wrong in selection? IT should be able to measure that, but for some reason it doesnt. Any idea?
TheCADWhisperer
Is selection 2 a straight line?
If not, where or how would “angle” be defined.
If it is, can’t you select the planar faces?
TheCADWhisperer
File>Export and then Attach your *.f3d file here and end all doubt.
jhackney1972
Your lines 1 and 2 must be curved.  If they are straight edges, thus straight lines, then it is direct reading.  See screen capture below.
Edit: @TheCADWhisperer  has the solution, I just added the screen capture.
John Hackney, Retired
TheCADWhisperer
Where did you go?
Ezekiel12
Hi @TheCADWhisperer
I am dumb... the selection 2 is trully curved... Sorry for your time 🙂
Thx,
Matt
chrisplyler
@Ezekiel12 wrote:
Hi @TheCADWhisperer
Hey, nobody is going to judge you based on this one. Plenty of us are, for example, good at math. Yet each and every one of us remember getting a test question wrong because of some dumb mistake like forgetting to make our answer value a negative, or something equally idiotic.
Now, there are certainly questions posted on this forum that we DO judge the writer for, but yours, in this case, isn't one of them.
