measure circle diameter
I'm having a really hard time getting fusion to build a tool path for a drill. I'm worried the diameter is wrong. If I select the circle, I get a path length, which I can divide by pi to get the diameter, but is there a way to measure the diameter directly?
masa.minohara
Hi @Anonymous,
Thank you for posting the question. Have you tried Measure command? Also, you can check the radius at the right bottom corner of Fusion screen. I hope this helps!
Masanobu Minohara
Product Support Specialist
Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
HughesTooling
From your description it sounds like it might not be a true circle. I've seen a couple of reasons this can happen. One the hole is at an angle to the surface , if you select the hole surface it will give a diameter. You might have to zoom in real close to select the surface, if you don't the measure tool will select the centre point. The second problem can be the hole was made with a spline and just looks like a circle. In both cases you will have trouble trying to select it in the CAM.
Mark
Mark Hughes
Owner, Hughes Tooling
HughesTooling
Here's an example of a hole at a slight angle.
Edge selected.
Surface selected.
Mark
Mark Hughes
Excellent point -- that is the problem! I drew the circle in illustrator, imported a dxf and extruded the sketch. I'll draw the circle in Fusion!
Tim
