Measure angles with moving joints
Hello guys,
I'm new to Fusion360 (less than 2 weeks of experience) but i have worked for many years with other CAD software (especially PTC CREO). I am working on a crank-slide like mechanism and I am trying to plot one angle respectively to another. In CREO there is a way to plot this really easily, but I did not find one in Fusion....
To say it differently, I'm moving one revolute joint and I want to measure the angle of another revolute joint driven by the first one. As the angles of the different joints are show on the assembly, I could just take some points and plot this but it's really a bad way to do it in my opinion. Is there a  better way to measure this ? If not, I think I just have to take value as interpolate this but I hope there is a tool I did not found as it would be much faster and much easier.
Thanks for your time and your help
Luc
PS: can't show you screenshots of my real work so I did the attached video with a random crank-slider to illustrate my problem
davebYYPCU
The video shows a piston, crank and conrod,
I have not worked out your problem.  Any measured angle would come from a sketch, surely?
Move either blue line the angle is read in the driven dimension.
Might help....
Thanks for the answer but I might not have been clear enough. I made a new video using CREO to show you what I really want to do. The problem is that I cannot use a sketch to measure it as my system is not planar (it's a 3D system with a conrod with 2 ball joints that moves 2 objects around revolute joints). So I used the piston, crank and conrod system to illustrate it
Luc
TheCADWhisperer
Autodesk Inventor Professional>Dynamic Simulation is the equivalent of that CREO functionality.
https://autode.sk/3wkoQi5
https://www.youtube.com/watch?v=WtwhTMrJDCg&list=PLp5izJt_zvN08mpY4UcYrzJV2N6QOLAIR&index=26
thanks for the answer ! So it will not be possible to do this directly with Fusion and I will have to use Inventor...
TheCADWhisperer
Fusion 360 does not have this functionality.
