McMaster component comes as multipule bodies
frostedtitan17
frostedtitan17
I'm trying to make a custom adapter that has a 1/16" NTPF thread on one side, and with no tool to model external npt threads I figured I'd import a part from McMaster then cut and join it. But this single part imports with multiple bodies that wont join together.
TheCADWhisperer
@frostedtitan17
Did you run a quality check on the imported geometry?
frostedtitan17
I know it's sloppy but I was just trying a couple things and just got stumped but the .f3d is now added.
frostedtitan17
Discovered the solution, I moved the extra bodies then used the align tool and they joined no problem after that.
TheCADWhisperer
@frostedtitan17
Can you work with the Attached geometry?
There are some gaps you might want to remove...
