Today McMaster-Carr is not usable.
If i open the panel sometimes the search bar is grayed out. So if you click on something MMC forwards to a login page. Sometimes you can click onto a category an go into it and after you will dive deeper to the specifications MMC forwards to a login page.
Sometimes the world is bad place, a really bad place..... ๐
Solved by macmanpb. Go to Solution.
I took a look at the Fusion integration with McMaster Carr and am not seeing this problem, can you tell if the Login page being shown is from the McMaster Carr web site, or if it is from some other system ? (A screenshot might help if you aren't sure).
Matt Pooley
On Behalf of the Fusion Dev Team
Hi Matt,
i have cleared fusions cache and since the problem is gone.
Thank you!
