McMaster Carr Component Separation
pastor.healer
pastor.healer
I wonder if someone would help me.  I have imported in a linear slide bearing from the McMaster Carr site but it is coming with a short section of linear rail as part of the assy.
I have brought the part as a step into a component folder in my design.
Then I saw that there were 3 parts in the 3d Step file.  The rail, the slide bearing and a zirc fitting. Each treated as bodies in the component folder.  When I try to delete the linear rail the whole set gets deleted.
How do I get rid of the rail without losing the bearing and zirc fitting?
Thanks for the help!  Incredible program...  🙂
Hi @pastor.healer
Instead of delete try remove.
pastor.healer
Worked perfectly!  Thanks John
Would you mind telling me what the difference is from a CAD perspective?  How is delete different from remove?
Thanks for your time
Glad I could help.
Here is a good topic on the difference between delete and remove.
http://forums.autodesk.com/t5/design-validate-document/what-is-the-difference-between-delete-and-rem...
