Matching T-spline Edge to Sketch Profile
I have a flat plane of t-spline faces that I'm trying to match to a sketch profile in the same plane projected from a solid body. I tried using the match command, but keep getting errors because I don't think it's the appropriate tool.
Is there another tool I could use for this? I know I can drag the vertices until it looks like it fits, or convert the faces to b-rep and then trim with the body, but I'd like the fit to be exact and still keep it t-spline so I can play with the topology in the center of the faces. I can't match the edge to the solid body, because the profile is offset from the solid body.
Any help is appreciated! Thank you,
Nevermind, pull tool worked very well.
michallach81
Here's match tool in action:
Note that for certain curve shapes we need specific t-spline faces layout to match.
Michał Lach
Designer
co-author
projektowanieproduktow.wordpress.com
