- Mute
- Permalink
- Report
I need to make about 8 identical parts. Not a problem to model the part, but a major headache to understand how to use Fusion360 to layout multiple of the same part.
1) Created component
2) Created Component Group for CAM Layout
3) Copied original component
4) Pasted copy into Component Group
5) Move to desired location
Step 5 is the problem. I can manually do all the math to figure out spacing, but that seems stupid in a CAD environment. What I want is 1/4 inch space between the parts.....easy for the first two pieces but when I have to place the 3rd it isn't so easy.....or at least I don't know how to do it easily. I've attached a screen shot and you will see the issue.....how do I get Fusion360 to space it out....no idea.
The measure tool is useless as it only measures perpendicular distances when the lines overlap......seems silly too.
Assembly joints are confusing and not sure I need them, but if so please help me understand that too.
