Manipulating pipe path
11:32 PM
I've got a design that is constructed of three pipes of different inner and outer diameters joined together as one body, essentially a bent tube with some differing diameters, but still one solid tube. I constructed it by making three different sketches, two straight lines for the short pipes on the ends and a conic curve for the long middle section that needs to be bent, then using the pipe tool to create each pipe.
What I need to do is change both the bend angle and total length of the middle, longest pipe section. It has a 12.5 degree bend, and needs a more dramatic one.
I tried editing the conic curve sketch that the pipe is based on, but got the "Project source is lost" error message.
Thank you in advance!
