Making geometric forms
Hi
I have attached a video of something I’d like to do on Fusion 360. I’m making some geometric objects and figured the easiest way would be to make triangles and move the points to create the object? Unless there is a better way to go about it?
thanks!
kevin
davebYYPCU
You edit the sketches for the patched / lofted shapes, and change the dimensions.  If the sketches are not fully defined, you click drag the sketch end points.
Might help....
ah yes, got it. Still getting my head round the basics and the terminology. Thank you!
