Making a hinge a joint.
wcarlsonM2NUS
Message 1 of 13
wcarlsonM2NUS
Trying to get the hang of using joints. Got this far, thought I could make the hinges joints with revolve and swing it open but I don't seem to be able to make the hinges joints.
What am I doing wrong?
Replies (12)
Message 2 of 13
jhackney1972
Your assembly only has one Component so you cannot apply Joints.
John Hackney, Retired
Message 3 of 13
jhackney1972
I created two Components from your Bodies using the Combine command and Convert Bodies to Components.  I added a Revolve Joint to one hinge.  Model is attached.
Message 4 of 13
TheCADWhisperer
@wcarlsonM2NUS
How will you get the pins into the holes in the real world?
Also, your first sketch was placed at the Origin but missing a Coincident Constraint to the Origin.
Message 5 of 13
wcarlsonM2NUS
This is to be a 3D print in place box. The pins should print in place. I've done a couple and they work well. I didn't realize about the Coincident Constraint.
Message 6 of 13
wcarlsonM2NUS
Hey John, I appreciate your help but I am unable to open the file. Says I need to update but it doesn't do an update. I'm using the hobby version.
Message 7 of 13
wcarlsonM2NUS
I couldn't figure out how to use the combine to create the components so I created two new components under Box called top and bottom. I dragged the corresponding bodies to the appropriate new components and then I was able to add the hinge.
Message 8 of 13
TheCADWhisperer
@wcarlsonM2NUS
Go to About...
What release does it show using (license type doesn't matter)?
Message 9 of 13
TheCADWhisperer
@wcarlsonM2NUS
You did good on clearance for the pins and holes - but you should have also allowed for a bit of clearance on these contacting faces or they will print merged.
Message 10 of 13
wcarlsonM2NUS
You are correct. It printed with the hinges frozen together. I applied the existing offset face to one of the contacting faces of the hinges and that fixed it.
Thanks!
Message 11 of 13
wcarlsonM2NUS
Fusion 2.0.20981 x86_64
Message 12 of 13
jhackney1972
Your Fusion application is way out of date.
Message 13 of 13
TheCADWhisperer
@wcarlsonM2NUS
Are you using a school computer or your own computer?
