making a drawing from an igs file
lyons11520
lyons11520
I am new to fusion 360 and have a project to make an adapter for a class build.
One of the other students designed the component and sent it to me as an .igs file.
I can open it in fusion but cannot make a drawing to dimension for manufacture.
How can I accomplish this?
I have attached a copy of the file.
wmhazzard
No file attached.
jeff_strater
more than likely, the IGES file contains only surface bodies, no solids.  You can only make a drawing of solid bodies.
Jeff Strater
Engineering Director
TheCADWhisperer
Can you Stitch the surface bodies into a solid body?
Can you request a STEP file rather than IGES?
Can you zip and then Attach the IGES File here?
lyons11520
I was able to get the original Solidworks file from the other student last night.
So I am going to use that instead.
