Make R.U.L.E #2 Easier - Feature Rename Dialog Fit To Text Width
tookemtoni
tookemtoni
I love Rule #2...If there is ever a problem with the design the renamed feature points me in the right direction.
But recently I have been using longer names which aren't fitting in the fixed size rename dialog box....
What do you think of making the feature rename dialog box fit to text width?
TrippyLighting
I think that is a splendid idea!
That same applies to any User Parameters field. Editing formulae is a painful experience and I often use Notes(mac) or Sticky Notes (Win) to edit formulae and then copy/paste them into the respective field.
Quite an anticlimactic experience for a Software with an otherwise modern and intuitive UI 😉
