Make diameter dimension tool "persistent"?
lindsaywilson88
lindsaywilson88
Is there a way of making the dimension tool stay in diameter mode, at least until deselected/reselected? (Diameter mode is chosen by right-clicking after selecting the two lines). When I'm dimensioning the sketch for a revolved part, I'll often want to add lots of diameter dimensions taken from the same revolve axis, and it gets a little slow having to right-click and choose "diameter" each time.
Solidworks, for example, has a feature where it knows if one of the selected lines is a centerline/construction line, and automatically changes the dimension to either radius or diameter, depending on where it's placed (this video shows an example of the behaviour: https://www.youtube.com/watch?v=kDzjLbV1VhU)
O.Tan
Post this up in IdeaStation and I'll give you a kudos! 😄
And let us know at what time do they start demonstrating the diameter/radius thing in the video
https://forums.autodesk.com/t5/ideastation-request-a-feature-or/idb-p/125
Omar Tan
Malaysia
Mac Pro (Late 2013) | 3.7 GHz Quad-Core Intel Xeon E5 | 12GB 1.8 GHz DDR3 ECC | Dual 2GB AMD FirePro D300
MacBook Pro 15" (Late 2016) | 2.6 GHz Quad-Core Intel Core i7 | 16GB 2.1 GHz LPDDR3 | 4GB AMD RadeonPro 460
macOS Sierra, Windows 10
HughesTooling
Take a look around 1.12 he adds a centre line then just moving the cursor below the centre line gives a diameter dimension.
Mark
Mark Hughes
Owner, Hughes Tooling
TheCADWhisperer
@O.Tan wrote:
...And let us know at what time do they start demonstrating the diameter/radius thing in the video
Here is similar example in Autodesk Inventor.  (:40-:45)
(Of course if only one dimension one might argue if changing to centerline is any faster, but if there are more than one diametral dimensions...)
lindsaywilson88
Hi @O.Tan@TheCADWhisperer@HughesTooling
Thanks for the replies! I've created a new idea request, here it is:
http://forums.autodesk.com/t5/ideastation-request-a-feature-or/diameter-dimension-tool-make-persiste...
Cheers,
Lindsay
