Make closed body
Make closed body
Make closed body
I have given up trying to close this body. Clicking in sketch line to line on all these points to make a closed loop so i can add a surface patch fails each time to become a loop and i cannot figure out why. There must be an easier way to put a lid on the bottom of this model and make a body from it. Please help!
jeff_strater
I would just use Patch + Stitch:
Jeff Strater
Engineering Director
davebYYPCU
ywpiai.PNGqtmiif.PNGI have too.  You can patch it in a fashion,  but still will not seal up, this corner is the area of concern, without a timeline, and stl basis, not worth more time, quicker to make it in Fusion from the get go.
Might help...
Thanks for your time, put me on the right course. Was trying to delineate all points manually into a polygon first. You indeed illustrated that there is a much easier way.
